Purchasing Distributor- Need INFO!
Old Jan 26, 2007 | 10:55 AM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
I am about to make my way towards a purchase of a new dizzy as they are called. I would like MSD or Accel...nothing else...my question is what is a Vacuum Advance and a Machanical Advance??? The Accel I want ONLY has Mechanical but the MSD I want has BOTH....whats the difference between the 2?
Thanks Much.
Old Jan 26, 2007 | 11:02 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Centrifugal advance increases RPM increases. Vacuum advance increases as vacuum increases while cruising. For a street car you want the one that has both vacuum and centrifugal advance.
Old Jan 26, 2007 | 11:09 AM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Centrifugal would be the mechanical right? Just verifying. Thanks alot.
Old Jan 26, 2007 | 11:27 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Pretty much.
That's all assuming that you're running a non-computer carburetor. You need something different if you have fuel injection or a computer carb.
Old Jan 26, 2007 | 11:43 AM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
I have the LO3 TBI motor.
Old Jan 26, 2007 | 12:39 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You don't want either of those, then. You'd need a distributor that will work with the computer.
Old Jan 26, 2007 | 12:54 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
SOB...Well here are the 2 that I am talking about.
MSD:
http://store.summitracing.com/partde...5&autoview=sku
ACCEL: This is computer controlled but only has mechanical advance
Old Jan 26, 2007 | 01:07 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Neither of those is what you want.
The Accel one seems a little strange to me... designed to work with factory connectors, but has centrifugal advance.
Old Jan 26, 2007 | 01:33 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
So I need something computer controlled with both vacuum and mechanical....but no HEI? What the hell do I buy then. Lol. I could have sworn the MSD one would have worked...SOB
Old Jan 26, 2007 | 03:28 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You need something with no mechanical or vacuum advance. The computer will control the timing.
"HEI" is meaningless, it's just the name that GM has used for all their electronic ignition systems since 1975.
Old Jan 26, 2007 | 05:59 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
DAMN....LMAO. Thanks alot....appreciate it. Well time to start my search.
Old Jan 27, 2007 | 07:12 AM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Just for curiosity why are you changing the distributor?Are you having problems with it?
As stated above if you want a new one,and you car still has all her computor controls,then you have to go with a computor controlled dist.The dwell and advance are handled by the module in the distributor sending signals to the ECM
wigmobile
Feb 26, 2025 02:56 PM
UltRoadWarrior9
Apr 28, 2020 10:39 PM
PurelyPMD
May 5, 2016 04:57 PM
Silver Spear
South East Region
18
Dec 4, 2015 09:59 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
