never grab hot wires...
Old Jan 30, 2007 | 09:25 AM
FireBird7Heaven's Avatar
i have recently perchased a 91 firbird rs from a used car dealer. though the body and engine are in good condition the display lights are currently not funtioning due to wireing issues. the previous owner spliced a red and a black wire together and ran it straight to the battery. wen i first looked at the car i poped the hood and began to chek it over. while it was open i noticed smoked riseing from around the battery. thats wen i noticed the red wire comeing from the body. i pulled it and broke the connection and now the lights no longer work obviously. waht should i do to repari them??
Old Jan 30, 2007 | 10:55 AM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
All circuits need protection. Inline fuse, fusable link, circuit breaker ... anything.
The color of wires are meaningless when it comes to people jerry rigging your car. You need to utilize a multimeter and find the voltage of the red wire, then black wire. Turn on the ignition and do the same. Then disconnect the battery and touch the multimeter on the red wire then to ground. The black wire then to ground.
Let us know what you come up with. Good luck dude.
Old Mar 1, 2007 | 07:50 AM
well upon further investigation it turns out the lights that were hangn down in front of the hub were added. the original lights are still in the hud im told. so now im going to do the obvious thing and check the fuse regardless of weher or not it works ill post ither friday or saturday to update u on how its goin. thanks guys!
-later
Old Mar 1, 2007 | 08:44 AM
rideon1200's Avatar
On Probation
Car: 2002 Formula
Engine: 5.7 LS1
Whoever did that could have been looking at quick fix for burned out bulbs or a blown fuse.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Thaney9
Oct 24, 2015 07:26 PM
mfp189
Sep 27, 2015 09:25 AM
ironbmt
Sep 27, 2015 06:00 AM
