Headlight problem
Old Jan 30, 2007 | 04:53 PM
MavViper's Avatar
Headlight problem
Have a little problem with my headlights. Low beams work fine, they will come on. The drivers side high beam will be very dimly lit. When I switch to high beams, the driver side lights will both light up but the passenger side won't. In fact both passenger side lights are off when I turn on the high beams.
Would it be a short on the passenger side wiring or perhaps the high beams on the passenger side are out causing both to go out when switched to high beams?
Old Jan 30, 2007 | 05:18 PM
Gramps's Avatar
Car: 87 Camaro IROC
try another bulb in there, perhaps one bulb is out and its screwin up the rest. what u can do is switch out a known working bulb and try that.
Ghettobird52
Jul 5, 2024 11:18 PM
GTAman
Mar 15, 2019 11:40 AM
DiabolicalRS
Aug 26, 2015 07:35 AM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
