ECM fault codes
Old Feb 3, 2007 | 09:56 PM
WaltB_FB92's Avatar
Car: Pontiac Firebird
Engine: V-8 305
Transmission: Automatic 4-speed
Axle/Gears: non posi
ECM fault codes
Is there any way to check the ECM out of the car I'm not able to pull the fault codes. I did check the CCCS dash bulb and its ok.
Old Feb 3, 2007 | 10:05 PM
thirdgenlover's Avatar
Car: 87 trans am
Engine: 350 TPI bored .040 over
Transmission: modified 700r4
Axle/Gears: stock spline, 3.73 Eaton posi
you might have a faulting ecm then if you cant pull the codes off of it, i couldnt on mine as well, it would work some days and not others. i thought it was my port wires, went through a flow chart and that pointed at the ecm being faulty, it was right at around 140.00 after core was recieved and the core charge deducted.
85 Jimmy
Sep 30, 2015 07:56 AM
eustodp
Sep 20, 2015 05:09 PM
Reese-J
Sep 14, 2015 02:43 PM
gt4373
Sep 9, 2015 10:29 AM
RyanJB
Sep 2, 2015 01:27 PM
