VATS
Old Feb 4, 2007 | 09:22 AM
SLONOMO91RS's Avatar
Car: 91 camaro rs
Engine: 305 tbi
Transmission: t-5
Axle/Gears: 3.08
VATS
If I bypass the vats do I put resistors in both wires?
Old Feb 4, 2007 | 01:55 PM
rhomanski's Avatar
Car: 86 firebird v6,86 corvette,88 GTA
Engine: 350 C.I.,2.8l.
Transmission: th700r4
Axle/Gears: 3:08,3:27
Only on the vats side I would think.
Old Feb 4, 2007 | 10:33 PM
Car: 91 camaro rs
Engine: 305 tbi
Transmission: t-5
Axle/Gears: 3.08
WHICH ONE IS THAT
Old Feb 5, 2007 | 10:18 AM
Car: 91 camaro rs
Engine: 305 tbi
Transmission: t-5
Axle/Gears: 3.08
I went and got the resistors so now I just need to know if they need to go on both wires.
Old Feb 5, 2007 | 02:56 PM
rhomanski's Avatar
Just put the resistor across the two wires on the auto mobile side of the harness coming from the column.That should work for you.
Old Feb 13, 2007 | 02:55 PM
Car: 91 camaro rs
Engine: 305 tbi
Transmission: t-5
Axle/Gears: 3.08
I tried to get a Reading from the wires coming out of the column and I got nothing. I tried putting a resistor in and it didn't work. Does the resistor have to the exact same as the key? I got a reading of 1480 from the key and I bought 1500 resistors and the security light stays on.
Old Feb 13, 2007 | 03:32 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
I made a drawing of what you need to do. 1500 should be close enough unless 1480 was already on the high end of the toleance.
RS Reaper
Oct 17, 2018 07:52 PM
djmarch
May 8, 2016 11:32 AM
AmorgetRS
Sep 28, 2015 09:33 PM
86White_T/A305
Sep 21, 2015 05:28 PM
Winchester1094
Sep 15, 2015 09:48 AM
