Wiring for ac to non ac
Old Feb 8, 2007 | 05:43 PM
1987camarosport's Avatar
Car: Camaro
Engine: worked 350
Transmission: automatic
Axle/Gears: 3:73
Alright, i have a non ac boc going into the car tomorrow, but im keeping the ac controler due to obvous reasons,, what wires do i need to hook up to get the motor to tun on.. the non ac box only has 4 wires are the controller wires the same or differnt?
Old Feb 8, 2007 | 06:13 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Take a look at this page.
https://www.thirdgen.org/forums/body...=wiring+ac+box
Old Feb 8, 2007 | 06:52 PM
Car: Camaro
Engine: worked 350
Axle/Gears: 3:73
OK thanks but it dosent tell me what wires i need to change and splice into.. i need like what colors go to what and what not..
Old Feb 8, 2007 | 08:28 PM
88KARRV6's Avatar
Car: All sold :-(
Engine: None
Transmission: None
Axle/Gears: None
Well, you can do like I did, and just reuse the A/C resistor and wiring.
what you do is unscrew the three prong resistor from your heaterbox and screw in the 4 prong resistor from your A/C box then Plug in the wiring.
Then you run the purple wire lead coming from the resistors to the positive plug on your motor (probably green), and the black to the grounding prong on the motor.
then you run the black wire to chassis ground.
If you want to see a pic, or want to use the non A/C wires (they are a little different) and want to see a diagram, let me know and I'll post them.
Old Feb 17, 2007 | 10:45 PM
sj85ta's Avatar
Car: 1985 Trans AM
Engine: 305 HO
Hi I am trying to do the same thing and would love to see the pictures of this as I do nnot have the old ac box and I am starting from scratch the best I can get right now is the fan to run on only one speed.
Old Feb 18, 2007 | 01:11 PM
88KARRV6's Avatar
Car: All sold :-(
Engine: None
Transmission: None
Axle/Gears: None
look in this thread:
https://www.thirdgen.org/forums/elec...e-wire-my.html
lots of info, and pictures.
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
