Strange Probelm with Startup
Old Feb 10, 2007 | 04:51 PM
mike_c's Avatar
Car: 1989 Trans Am GTA
Axle/Gears: 9 Bolt 3.70
Last night I took my car out and on the way home, I stopped to get some gas. After I finished pumping, I went to start the car up and the starter wouldn't engage at all. I could hear the fuel pump working and everything else in the car worked too. The starter just wouldn't work. At this point I'm thinking the starter solenoid or the starter itself is bad. Here's the weird part: One of the guys who worked at the gas station saw I was having trouble and told me I wad to move the car away from the pump. So I put it in neutral and had my friend who was with me push it into an empy parking space behind me. So then I went to start it up again and it fired right up, no hesitation with the starter or anyting. After I got it home, I turned it off and attempted to start it again and it fired right up again without any trouble. So today I tried starting it a couple times and didn't have any trouble with it again. Does anyone know what could be causing it to not start up once and then not have any more trouble? Thanks in advance.
Old Feb 12, 2007 | 09:46 AM
Fullsizewagon's Avatar
Engine: '85 Monte SS L69 305
Transmission: TH 200-4R
It's a forewarning that something is developing in the wiring/ solenoid/ or the brushes may be wearing out. Next time it happens you could try to give the starter a knock with the handle of something. Worked everytime for me once upon a time.
Fanatic1074
Oct 3, 2022 05:57 AM
RS Reaper
Oct 17, 2018 07:52 PM
BWilcox
Sep 20, 2015 12:19 PM
CatmanFS
Sep 19, 2015 09:00 AM
IROCtometal
Sep 9, 2015 10:01 AM
