??? having problems after a steering column switch
Old Feb 14, 2007 | 07:32 PM
yt91rs's Avatar
Car: 91 camaro RS
Engine: 305 TBI
Transmission: Auto 4 O/D
Axle/Gears: which one i have broke three
i switched the complete steering column in my 91 camaro i used the old vats unite, in order to do that i took both keys to a dealership had them cut the right design for the starter switch and the carbon chip for the old vats unite, so when i try to start my car it acts like it is in gear or something, checked all gear linkages and they are good, the check engine light is staying on and when checked it gave code 53 i am very confused can anyone help?
Old Aug 13, 2007 | 11:57 PM
w_mortell's Avatar
Car: 91 Camaro
Engine: 3.1 V6
Transmission: Automatic
Axle/Gears: stock(what could be better!!)
Re: ??? having problems after a steering column switch
did you use your old ignition cylinder....if you switch to your old ignition cylinder, it will work. just run the vats wires down the column, and plug it in, it will work, well.!
Jorlain
Aug 24, 2022 05:11 PM
Out-Cast
Mar 22, 2019 09:39 PM
Out-Cast
Aug 23, 2015 06:33 AM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Bull86
Aug 10, 2015 05:43 PM
