Ignition coil wires- which do what?
Old Feb 19, 2007 | 07:40 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I'm wiring up a new ignition and I'm trying to double check what each wire does to prevent any problems. Can someone explain what each wire is on the coil in this diagram from my Chilton manual?
Attached Thumbnails Ignition coil wires- which do what?-0900823d80163fe5.gif
Old Feb 19, 2007 | 08:24 PM
Corky's Avatar
Car: 88 Firebird - SOLD!
Engine: 2.8L
If my feeble mind serves me right.
Pink from ign switch = +12v
Pink & White = pickup coil trigger wires
Black = Ground
Corky
Old Feb 20, 2007 | 08:21 AM
Car: 86 T/A
Engine: HSR 355
Anyone else can confirm?
Old Feb 21, 2007 | 01:09 AM
Siggy's Avatar
Car: 1988 Camaro IROC LB9 F
Engine: 305 HO EFI
Transmission: TH700R4
Axle/Gears: GU5 LS 3.23
Looks strange to me, on my 88 TPI 305 it goes...(factory manual)
white is trigger from the EST(fires coil)
white is also tacho feed
pink is 12vdc from ignition swtich (run), powers coil and EST
By your diagram this means that the pink wire from the EST should go where the white (inst-tacho) is shown and the white (inst-tacho) goes where it shows the pink wire ie; common with the white trigger wire.
I checked both my factory manual, a Haynes and the Chilton (28282)..the Chilton does not agree with the other two, looks wrong. Actually the AB input to the EST is for A=ignition power 12vdc, B is trigger for coil and switches to earth/Gnd to fire coil. The Chilton has AB inputs shorted, can't be right?
Be careful.
Old Feb 21, 2007 | 11:15 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Doesn't look right to me, either.
Old Feb 21, 2007 | 01:31 PM
MONSTERPARTS's Avatar
This diagram you have is definatly wrong
Old Feb 21, 2007 | 01:44 PM
Car: 86 T/A
Engine: HSR 355
It's not the first time that stupid book's been wrong- ugh.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
Gunner242
Dec 25, 2015 04:49 PM
school boy
Oct 22, 2015 11:47 AM
92rsvortec350
19
Oct 9, 2015 09:39 AM
