86 z28 ignition problem
Old Feb 21, 2007 | 01:31 PM
tittan1500's Avatar
hi i have a 86 z28 it was a tbi but it has a carb now and the wiring is extreamly bad!!! i have had only problems with the wiring.
first off when i shut the door and stick the key in i get power and it makes a buzzing noise but my head lights wont work and when i turn the key to start i loose all power. and still no head lights.
could this be a problem with the ignition swich
the other day i was geting out of the car and my foot got stuck on a wire that went under the kick pannel and under the center councle by the radio and thats when it stoped working i cannot find where this wire went to
Old Feb 21, 2007 | 11:30 PM
86z28305's Avatar
Car: 1986 Chevrolet Camaro Z28/99 Aurora
Engine: LB9 5.0 TPI/4.0 V8
Transmission: 700r4/?
Axle/Gears: 2.73/3.08
Are your battery terminals tightened down? Are they crusted and nasty? I know that if your battery terminals are loose that when you turn the key you will lose all power and you wait a minute power comes back. But then again you said your wiring was a mess.
Infested
May 22, 2018 11:56 PM
db057
Aug 22, 2015 08:17 PM
Bryan F
Aug 18, 2015 02:28 PM
92camaroJoe
Aug 13, 2015 06:07 AM
