Engine back in, no spark. LG4 Carb.
Old Feb 4, 2007 | 09:29 AM
IOWZ28UK's Avatar
Car: 1987 Z28
Engine: 305ci
Transmission: 700-R4
I've just put the engine back in my 87. Everthing wired correctly as far as i can see. cranks but no spark. is there a easy method for testing the module in the distributor and the spark control module near the l/h fender. Parts are only available by post where i live in the uk.
Any help and advise greatly appreciated
Old Feb 4, 2007 | 10:14 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Some shops can test the module. These parts shouldn't go bad from an engine swap though. I assume you pulled the dist in the swap process? I'd double check all your connections and verify 12 volts to the coil. I've been stumped myself on occasion only to find I'd left off a lead somewhere.
Old Feb 4, 2007 | 10:23 AM
IOWZ28UK's Avatar
Car: 1987 Z28
Engine: 305ci
The dist. was pretty mucky inside. cleaned it all up fitted new rotor and cap, new plug leads, just found some info on autozone site. gonna retest pickup coil and main coil, double check all wiring connections. according to auto zone the fault is probably in the dist. either the module or coil..
Old Feb 4, 2007 | 10:38 AM
naf's Avatar
naf
It's a small cap. When you took it apart how did it look inside? The pickup coil/reluctors on these can get corroded with brittle insulation. Taking it apart and cleaning it could have been the last push it needed to die.
Old Feb 4, 2007 | 10:46 AM
IOWZ28UK's Avatar
Car: 1987 Z28
Engine: 305ci
the pickup coil is still in one piece, although looks fragile. the reluctors? i guess the magnet sensors were rusted. i cleaned them up carefully with emery cloth and blew dust out with air line. Gonna check coils now as it will be dark here soon.
Old Feb 4, 2007 | 11:12 AM
IOWZ28UK's Avatar
Car: 1987 Z28
Engine: 305ci
Both coils checkout ok. with resistance values spot on. Looks like it may be the module in the dist. or the electronic spark control!
New module should arrive today, Hope it works!
Old Feb 17, 2007 | 05:47 AM
IOWZ28UK's Avatar
Car: 1987 Z28
Engine: 305ci
Fitted new module in dizzy, fired first time. Total cost of module including post. £47 about us$90 I wanna live in the States!!!
Old Feb 22, 2007 | 12:20 AM
Siggy's Avatar
Car: 1988 Camaro IROC LB9 F
Engine: 305 HO EFI
Transmission: TH700R4
Axle/Gears: GU5 LS 3.23
I fitted a Crane ignition and messed up the wiring....I went through 2 EST modules before I found the fault, lucky me in Oz they cost AU$48.00.
theshackle
Sep 17, 2020 08:26 AM
justin57
Aug 20, 2015 07:05 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
matthew911
Aug 12, 2015 09:38 AM
