I'm retarded, can someone tell me the obvious?
Old Feb 26, 2007 | 03:41 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
I've been trying to figure out how to install my fog lights... I've got hte lights on my car, they sure do look nice, but they're not functional.
I've seen a few good threads on it, some good diagrams, etc.
I wire up my guitars all the time. Very simple stuff, but I knew enough to get by there.
Im looking at this diagram:
http://www.classictruckshop.com/club...ch/foglite.jpg
Most of it seems simple enough, but I've never messed with car electronics in my life. Looking at the circuitry it's all very simple, it's the logistics that confuse me.
How exactly does one get a connection straight from the battery? Certainly it's not hard and there are a million ways to do it, I'm just not sure what the proper correct way is. Tap a wire you know is hot? I mean obviously shoving a wire down into the terminal on the battery will work but I doubt that's a good idea.
Secondly, I see the line from the fuse box. Also seems simple enough but a similar question, I've never messed with a fuse box before. How do you get a hot lead from it? Are there terminals you solder to or what?
I guess my background in electronics wears a little thin when dealing with active circuits. Guitar electronics are all passive.
Old Feb 26, 2007 | 12:30 PM
Corky's Avatar
Car: 88 Firebird - SOLD!
Engine: 2.8L
Here's what I would do...
Wire as much as possible INSIDE the car. In your case keep the relay and battery wiring inside under the dash. I usually pull battery power from the bat terminal on the fuse block. I use a wire with a spade connector on the end & plug it into the bat terminal in the fuse block. As your diagram shows, always equip that wire with an appropriately sized fuse as close to the source as possible. If this wire is not fuse protected, a dead short in your circuit WILL cause a fire.
I protect all wires with plastic loom, especially wires running thru the firewall & in the engine bay. Make sure your connections for the lights are good & solid and seal them all with heat shrink.
Good Luck,
Corky
Old Feb 26, 2007 | 12:35 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
If you want to connect directly to the battery (it is useful sometimes) they sell a battery terminal at autozone that allows you to clamp other connectors to it.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Mark_ZZ3
May 24, 2018 01:02 PM
loud91rs
Oct 5, 2015 10:05 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
Damon
Sep 26, 2015 04:29 PM
