Tail lights/Interior lights...
Old Feb 26, 2007 | 08:01 PM
csreid's Avatar
Car: 1988 Pontiac Firebird Trans Am GTA
Engine: 305 boat anchor
Axle/Gears: 2.73s? Not sure....
Okay, I tried the search engine, but I'm relatively new here, and I didn't find anything, so if I missed something, I'm sorry.
Also, I'm relatively new to cars in general, so this may or may not be a stupid question:
A while back, I was out driving, and my stereo wouldn't turn on. It's a new CD player, and was very, very poorly installed before I got the car, and was loose in the hole. I wiggled it around some (this had worked before when this was happening...) and all of the lights inside the car, except for the digital instruments, turned off. The lights next to the shifter, that indicate the current gear turned off, the lights on the steering wheel (radio controls) turned off, and the lights to the climate control turned off. I later discovered that my tail lights would not come on.
The car is a 1988 Trans Am GTA with a good many miles... Any help would be greatly appreciated.
Old Feb 26, 2007 | 08:08 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Axle/Gears: 3.55 Wavetrac
You might have blown a fuse because of the unit being loose and maybe grounded out a wire.Check your fuse box for a blown fuse, should be listed as Crtsy(courtesy lights) or may just be listed on the box as lts(lights). That is where I would start. If that's the case, you need to fix that loose CD unit so it does not reoccur. Badman
Old Feb 28, 2007 | 07:07 AM
csreid's Avatar
Ok, well, that fixed the tail lights. Ironically enough, when those came back, the headlights quit.
Old Feb 28, 2007 | 11:10 AM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Need to check all fuses in fuse box. Also see if any wires going to Cd deck rubbing or chafing on frame or body.Look under dash for same. Badman
Old Mar 1, 2007 | 12:14 PM
csreid's Avatar
Okay... turned out that when I was fiddling around in the fuse box, I knocked one loose. I fixed that... everything works now. Thanks!
Old Mar 1, 2007 | 01:00 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Get the wiring on that CD changer fixed. Avoid more problems in the future. Glad to help. Badman
3rdgenparts
May 21, 2016 11:50 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
