Wipers only work on high. What else do I replace?
Old Mar 4, 2007 | 07:25 PM
Slick71ss's Avatar
Car: 87 Iroc
Axle/Gears: 3:27
My wipers only work on high. When you first turn them on, they flinch a few times before working. They also won't park on their own, you have to manually park them by bumping the switch to high until they're at the bottom.
Is the wiper switch on the turn signal lever the only switch involved here, or is there a separate switch inside the column? I'm not sure if I have a bad switch or wiper motor? Please help! I don't have delay wipers or cruise if that helps.
Old Mar 9, 2007 | 12:32 PM
Stephen's Avatar
Car: 87 GTA
I suppose the easiest point to test it, would be at the wiper motor itself, Easier to reach the wiring, than in the column or under the dash. See if the switch is even sending a signal at all. If it is, then try hot wiring the motor, to see if the motor is good.
Frozer!!!
Jan 19, 2024 04:55 PM
specialized
Jun 18, 2022 09:26 AM
slade5612
Aug 11, 2015 07:19 PM
marcusaw
Aug 10, 2015 08:13 AM
Fronzizzle
Aug 9, 2015 01:15 PM
