Passenger side block and head sensors. Wires Cut Need help.
Old Mar 8, 2007 | 08:24 PM
BigBoi4Lyph's Avatar
Car: 89 Iroc
Engine: 5.7 TPI
Axle/Gears: 9 bolt Borg Warner Disk Brake Posi
SO on my passenger side under the car i found 2 wires having down and 2 sensors one was in the lower block right aboved the lip for the oil pan to mate agaist. Knock sensor? (im no shure if its the knock sensor but thats whats ive gotten from everything sofar) Please correct me if im worng
And the other was at the top in the cylander head between 8 adn 6 which i found to be the secondary cooling fan switch.
Now i found 2 wires on this side one was black and one was white or close to white.
No which sensor do each of these wire run to
Black to fan switch and white to knock sensor?
Thanks and where could i buy new sensor/switches with the plug and wire to hook them all back up? Thanks
Also ive heard of a lower tempature switch for the seconday fan?
Old Mar 8, 2007 | 09:44 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
there is also an oil pressure switch with two wires on driver side just above the oil filter, spade ends
but yeah you will have a knock sensor if its 85 or so and up
and temp switches in both heads, rear of the head(for fan) on pass side and middle of head on driver side(for dash)
and so on
wire plugs you may be able to find some at parts store, if not then junk yard
switches are sold at parts stores most are around 20 bucks each
you can look them up online and get an idea of price at advanceauto.com
in which is parts america
good luck
Old Mar 8, 2007 | 09:52 PM
Car: 89 Iroc
Engine: 5.7 TPI
Thanks alot. i havent been able to find out what color wire is supposed to go to the knock sensor tho autozones diagram isten showing the detination sensor for 89 ? but i know how to test both wires now i ground each one at a time with the key on and one of them sould turn on my secondary fan
Old Mar 8, 2007 | 10:27 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
hum, thats pretty risky, imho
ground the wrong one and say bye bye to the ECM or a fuse-able link, etc.
good luck
Old Mar 8, 2007 | 10:31 PM
Car: 89 Iroc
Engine: 5.7 TPI
Yea i actually just located some information the white wire goes to the knock senso and the black wire goes to the fan switch. The white wire had the plug still on it and i pluged it into the knock sensor today i wonder how much its helping of it it even works will the knock sensor cause the car TPI to be hard to start? Elongated cranking periods before firing?
Ikes 91Z
Dec 9, 2015 03:49 PM
LittleFranks
Aug 20, 2015 03:55 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
