help troubleshooting my non-working blinkers
Old Mar 11, 2007 | 01:37 PM
mreld3r's Avatar
Car: 1986 Iroc, 89RS
Engine: 350 tpi, 350 tbi
Transmission: 700r4,700r4
Axle/Gears: 4.10,2.73
my blinkers dont work, where do i start
Old Mar 11, 2007 | 11:06 PM
82CrossFire Z28's Avatar
Car: 82 Camaro Z28, 88 IROC-Z
Engine: 5.0L TBI., 5.7TPI
Transmission: Auto TH200C, 700R4
Axle/Gears: 3.23 posi, ones that rotate!
Suggestions from the 82 service manual......
If ALL turn lights don't flash....
1. Check TURN B/U FUSE by operating BACK UP LIGHTs (B/U = Back Up)
IF Back Up lights don't work, replace the Turn B/U Fuse
2. Check TURN FLASHER, TURN-HAZARD SWITCH ASSEMBLY, and related wiring. {Turn Flasher is mounted ABOVE the convience center. The convience center is on rith side of drives's dash, just left of the console. The ALDL is mounted to the bottom of the Convience Center. I think you will have to remove the convience center to get to the Turn Flasher. You can pick up a new flasher at any auto parts store, in the electrical section.
Hazard switch is mounted on the steering column, right side.}
If only one turn light doesn't flash, check that its ground is clean and tight.
Let us know if you need additional help.
Dave
Old Mar 11, 2007 | 11:52 PM
Grim'91Z's Avatar
Car: 1991 Camaro Z28
Engine: L98 5.7L V8
Transmission: 700R4 Auto
Either your bulb(s), socket(s), or relay.
Old Mar 18, 2007 | 08:58 AM
mreld3r's Avatar
First off i apoligize for posting a really BAD question. No details, just a dumb question.
Second thanks for the great responses. I haven't had time to work on the car, but I will get back to ya when I do.
Man, i am impressed. You took the time to give me a really great response,,,thanks. You guys are the bomb..
Old Mar 18, 2007 | 11:37 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Replace the Flasher unit under the dash. 99 44/100% of the time this is the problem.
RABMAN
Interior Parts Wanted
Sep 18, 2015 09:02 PM
Jk_Under
Sep 2, 2015 10:59 PM
bklucas12
Jan 11, 2002 06:44 AM
super83Z
Jun 2, 2001 10:44 AM
Jimmy91RS
Sep 28, 2000 02:16 PM
