Speed Limiter/Governor delete
Car: 91 camaro T-Tops
Transmission: Borg T5
Alright, I have a 1991 Camaro RS L03/T5 and my governor kicks in at 115mph. How do I eliminate this? Is there an easy way without reflashing my ECM? Or is it possible to "open"(toggle switch inline w/ speed sensor) until past the limited speed and close the switch to have a functioning speedo 116+mph? I have heard tidbits about a Zemco unit that does what I want, but cannot find one, or even who sells them. let alone the instructions I can find, all have to do w/ automatics. If there is a way, does it throw a Check eng. light? Is there an optional ECM some year that doesn't have this? Do the TPI/carb/MPFI vehicles have the same limited speed?
I know that some vehicles can be driven over the limited speed in direct drive then shifted into O/D or w/ an auto put into O/D. But that doesn't work on my vehicle. Direct drive ends ~110 and the governor is set at 115.
thanks in advance.
thanks in advance.
Does anybody NEED to go faster than 75? I just wanna know if there's an easy way, or if it requires a reprogrammed chip. I can setup wiring harnesses, fix electrical problems and what not. I just don't wanna have to dig through EWD's to figure out signal wave patterns, if it's bypassable or what all my VSS is connected to.
Basically, Has anyone done this? Know how to, have the same problem or willing to try?
Car: 84 trans am
Transmission: built 700r4
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
Might as well get the chip...I am happy with my TBI chip....And YES alot of people need to go faster than 115...BTW, you are lucky my car cut out at 110....
Car: 1987 Z28
Engine: LG4
Car: 89 RS, 92 Z28
No, no fun...BTW, its not that I would, BUT its nice to know I could........LOL.....
My '89 celica could go faster. Enough said. though it was at redline in 5th gear at 122.
And I am more curious b/c I want to play w/ my car. If I switch over to a 350TBI, am I going to have the same governor? I'd rather just eliminate it. The less big brother has programmed into my vehicle the better.
No, I'm not that retard that does 100+ in suburban streets, I just wanna be able to hold a speed that's respectable. For the love of all that's holy, I couldn't keep up w/ two of my classmates in n/a eclipse/talons b/c they could hold 120-140 on a trip south. They're front wheel drive and "ricers" they aren't supposed to be able to achieve higher speeds than me.
Car: 1987 Z28
Engine: LG4
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Bottom line: The speed limiter is in the chip, and the best way to remove it is to find someone to burn you a new custom chip without it. A "Hypertech" or "JET" chip off the shelf will still have the speed limiter in it.
Car: 1991 Camaro Z28
Engine: L98 5.7L V8
Transmission: 700R4 Auto
The only reason I could see removing the limiter is if your trap speeds are higher than said limited speed. Nobody should be going in excess speeds on the streets (I'll admit I've hit well over 100 a couple times on empty freeways).
Car: 89 RS, 92 Z28
Hey Toyota, just kidding man, i knew ya wasnt talking to me...............Just having a little fun.............BTW, not sure about Jet, or Hyperterch, but TBICHIPS do not have the limiter in them...Tom
Transmission: Built 700r4
Only thing is before I did it i read it can cause your computer to go bad faster than usual due to more resistance in the vss. After about 3 months, my computer did crap out. I dont know if it was from the vss OR from being 12 years old or more. Either way, this will work but the correct way to do it is to get a new chip. Hope that helped?
works for me. Thanks, that's what I wanted to know... basically. I don't like the idea of killing my computer though. eventually, I would like to convert it over to a 350 TBI, break it in and switch to a true fuel injection setup. I'm not set on any plan yet, but I'd like to see if the car would still pull decently through 5th gear, instead of only getting +5-10mph. Are all the TPI cars limited at 110? I have a "superchip" brand chip in it now(came in it when purchased), might that be why it's higher than your 305 TPI??
Car: 1983 Z28
Engine: GMPP 350, 92 TPI
Axle/Gears: Auburn gear posi, 3.08
Re: Speed Limiter/Governor delete
Or you can buy this and lower your fan temp and whatever else you want to do.
http://tpiparts.net/inc/sdetail/657
sounds great, and looks affordable. I'm converting to (real) fuel injection later but thanks for the link. Though I haven't decided what system I want to use yet.
