No Power too Fuel pump, headlights, rear hatch and wont start
Old Mar 23, 2007 | 02:49 PM
91transamGTA's Avatar
Car: 91 Trans Am GTA
Transmission: 5 speed
Cant find the problem anywheres the car will turn over for me but it wont start because the fuel pump is not coming on got me stumped been at it for a week now cant figure nothing out
Old Mar 23, 2007 | 02:57 PM
j dezzy's Avatar
Car: 87 TA
Re: No Power too Fuel pump, headlights, rear hatch and wont start
try putting direct power to the fuel pump and see if it primes. Have you checked the relay and fuse?
Old Mar 23, 2007 | 03:04 PM
the fuel pump is in the tank of my car i checked all the fuses underneith the dash where would the relay be at..... thanks for the help....where would i hook direct power up too it at?
Old Mar 23, 2007 | 03:12 PM
j dezzy's Avatar
Car: 87 TA
the relay is one of the 2 or three that are mounted on the firewall behind your brake booster. I think the 2 best ways you can get at the wiring for your fuel is to either pull up the carpet behind your backseats, the inside connector is pop riveted right there. but the way I always do it is to crawl up under the car and find the connector and unplug it and run direct power to it. there whould be 3 wires on the connector, just power each one. if the pump doesn't prime donig this, then your pump is dead.
Old Mar 23, 2007 | 04:11 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
A stupid suggestion but make sure that the single-fuse holder by the battery has a good 20A fuse in it. That's the power source for your fuel pump and cooling fans.
Find the fuel pump relay and check its operation and signals with voltmeter. You can find all schematics you might need on our ATGO Tech DB wiring page.
If you need help troubleshooting the relay, let me know.
Lou
Old Mar 24, 2007 | 11:26 AM
Ok i got somthing figured out that the fuel pump does work if i hook up power to the purple and gray wire goin to my fuel pump and negitive to the black one and the car will start well them wires are hooked up... so what could be the problem the ground maby?? Another thing is when i turn my key forward my seat belt light is sapose to come on and it does come on untill i hook the fuel pump up to the battery also my radio wouldnt come on now it will when i hook the fuel pump up to the battery it got me stumped what could be goin on
Old Mar 24, 2007 | 05:17 PM
fbird92's Avatar
Car: '92 firebird
Engine: 305 HO
Transmission: 700R4 TCI performance
Axle/Gears: 10 bolt disc brake 3:42 slp auburn
Did you find the fuse under the hood that is either on the radiator support or on the passenger fender? This fuse controls your fuel pump and also your oil pressure switch. I had the problem where the wire to the oil pressure switch shorted and broke and blew that fure and would cause the car not to run. If anything is wrong with the oil pressure switch or the wiring it will cut power to your car and allow it not to run. I would suggest finding that fuse and if it is gone than go under the car and look at the oil pressure switch and the wiring.
Old Mar 24, 2007 | 06:05 PM
83z28camaro's Avatar
Car: '01 GMC Sierra
Engine: 5.3L
Transmission: 4L60e
Axle/Gears: 3.73 eaton locker
Check the fuse by the battery and the fuseable links on the starter. Are you connecting power to the purple wire at the fuel pump? It sounds like you have a fusible link problem. That is the most common problems that cause alot of electrical things to stop working.
Old Mar 24, 2007 | 11:42 PM
Brads RS's Avatar
The best way and safe way to check the fuel pump circuit is to find the relay, remove it, look at the connector and find the large orange wire and grey wire, jumper them together. The fuel pump should run untill you remove the wire. this will tell you that your power and grounds are good for your fuel pump. Now look at the connector and find the green with white tracer wire and the black with a white tracer or black. The black should be a good ground and the green/white white is the signal from the computer to turn the fuel pump on. Connect a test light between them and the light should come on for about 2 or 3 secs as soon as you turn the key on. This will tell you that the computer is doing its job. Now the oil press switch also has a lot to do with all of this, as mentioned above if it is faulty the car wont run unless you jumper the fuel pump on as i said earlier. Hope i helped
Old Mar 25, 2007 | 08:26 AM
Ok thanks for the help guys i'll go take a look at all this stuff today and see what I find and I'll post up again later on today thanks again for all the help
Old Mar 25, 2007 | 06:50 PM
I fixed the problem but never really found out what it was... I took a wire from the negitive post on my batter and put it on bare metal on the car and bolted it down and the car seems to work perfectly fine now better then it did all last summer
Old Mar 25, 2007 | 07:24 PM
Car: '01 GMC Sierra
Engine: 5.3L
Transmission: 4L60e
You had a bad body ground.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
justin57
Aug 20, 2015 07:05 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
