How to replace sensor weatherpak connector
Old Mar 12, 2007 | 06:37 PM
CochinoFilipino's Avatar
Car: '67 C10
Engine: 5.0 TPI
Axle/Gears: Yes
Do you just buy the connector prewired and splice them in?
Or do you somehow wire directly into the connector? If so, how?
Old Mar 13, 2007 | 09:56 PM
Brads RS's Avatar
Buy it prewired. Unless you have the crimping tool and the terminals.
Old Mar 13, 2007 | 10:06 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If it's just the plastic shell on the factory connector that's broken, you can remove the pins from it and insert them into a replacement shell. If the wires or pins are damaged, you can cut the old connector off and crimp new pins on, or you can buy a new connector with pigtails attached and splice onto the factory wires.
Old Mar 13, 2007 | 10:44 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
If you get one with the pigtail from GM, all the wires will be white. I found that out with my digital EGR connector - 4 white wires, and I ended up mis wiring the valve. Parts guy told me it was because it can fit other applications, but I think it reduces manufacturing costs. I know it costs less (in this case by 75%) to use only one color.
eightsixseven
Dec 16, 2024 01:50 PM
Frozer!!!
Jan 19, 2024 04:55 PM
mizz0313
Aug 12, 2015 06:45 AM
92purpz28
Aug 11, 2015 02:30 PM
