I BOUGHT THE WRONG DISTRIBUTOR DIDNT I
Old Mar 13, 2007 | 04:08 PM
crazy85iroc's Avatar
Hey guys I have a tpi 305 out of an 88. I Just about finshed installing my stealth ram, and dropped in my distributor. But when looking at my stock distributor, compared to my new one, my old one has a lot more wires and connectors!!!!! I bought the "MSD Pro-Billet Small Diameter Chevrolet V8 Distributor PN 8570" I was reading on the forums and such and saw that I need a small cap dizzy to fit my HSR. It never enterned my mind that there might be different or specific dizzys!?!?!?!?!?!?!?!? Well if I did buy the wrong dizzy, could someone please tell what one I do need. And Please let me know if there is anyway that I could buy or make something to get this dizzy to work. AHHHHHHHHHHHHHHHHHHHHHHH
Old Mar 13, 2007 | 04:12 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The 8570 is a non-computer controlled magnetic trigger with centrifugal advance that must be used with an ignition box like an MSD 6.
You need a "ready-to-run" distirbutor, like the 8366.
Old Mar 14, 2007 | 03:47 PM
ok so, i looked at the picture but my dizzy has wires coming off it with a plug on the end. This one has plugs on the dizzys with no wires coming off it. My car was a factory 85tpi but the motor was replaced, is it possible that when the sway was done the motor was taken out of an 88 and the factory dizzy was used?
Old Mar 14, 2007 | 04:00 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It doesn't matter much where the plugs are on a piece of wire, or on the distributor itself, as long as they're there, and they share the same purpose.
Old Mar 14, 2007 | 04:05 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
our original one is EST controlled
the new one is for without EST im sure
80-up are EST
in stock form
good luck
Old Mar 16, 2007 | 07:52 AM
So i should get the "ready-to-run" distirbutor, like the 8366, or is that the wrong dizzy also?
Old Mar 16, 2007 | 10:29 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
That should be the one. Might want to do a quick search to see if anyone else has used it with the stealth ram.
Old Mar 16, 2007 | 11:19 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
The 8366 is the one you want (this is what I am running), but you will probably have to make some wiring modifications.
We will need to see images of the wires/connectors you currently have so that we can tell you what needs to be done, since your car is an 85 with an 88 setup and I don't know what the previous owners did with the wiring.
Old Mar 16, 2007 | 11:40 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
I'm also running MSD part #8366 with my Stealthram. This was on a 1991 TPI car and a direct replacement for my setup though.
Old Mar 22, 2008 | 12:00 PM
snowstorm's Avatar
Car: -86 camaro Z28
Engine: 383 w/HSR com950
Transmission: 700R4 raptor, level III
Axle/Gears: Strange 12-Bolt, 3.42
Re: I BOUGHT THE WRONG DISTRIBUTOR DIDNT I
Hi guys/girls, hoping you can help me with an ignition-parts issue. My car is a -86 Z28, once upon a time housing a 305 tpi. Now, the engine is a -72 350 4-bolt. I am waiting for my HSR pn: 91404211, and the CompCams kit CCA-CL12-430-8, witch is a retro-fit hydraulic roller cam kit.
When I called the techhelp at CompCams to ask if my new-ordered MSD-8366 will fit to the distributor-gear on the cam, he asked what color the gear on the distributor was. Well, since I don’t have the distributor yet I didn’t now. But I now that MSD list the 8366 as a direct-fit on sb -87 to -95. He told the parts should go together; I was not convinced by his answer. Since the parts have to be shipped to Norway I want to be safe about this before they are shipped.
Is there anyone out there who has any thoughts about the matter? Have I ordered the wrong distributor?
evilstuie
Jan 9, 2020 08:29 PM
Caspar
Jun 19, 2016 11:19 PM
86IROC112
Sep 7, 2015 01:37 PM
355sbcTPI
Aug 19, 2015 04:38 PM
johanlindgren
Aug 16, 2015 12:16 AM
