umm why is it still here?
Old Mar 15, 2007 | 07:50 PM
VenomX-87's Avatar
Car: 1984 Trans-Am WS6
Engine: WAS: 5.0HO, SOON: ZZ383-425HP.
Transmission: 700R4 with shift kit
Hi, ok i have a 84 non cc carb/distriburor, no emissions b.s. but for some reason i still have a wired up Computer. Why would my car need this, what would it controll?
Old Mar 15, 2007 | 07:57 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
nothing cept 700r4 lockup if so equipped
i removed the entire computer harness from my 82 but i have a th350 in it no lockup and swapped on non-EST carb and HEI
good luck
Old Mar 15, 2007 | 08:57 PM
VenomX-87's Avatar
Is there anything i can do to get around that?
Coz i don't want it in there if i don't need it.
Old Mar 16, 2007 | 11:29 AM
Fullsizewagon's Avatar
Engine: '85 Monte SS L69 305
Transmission: TH 200-4R
W/o the cc carb & dist the computer would be in limp mode anyway (doesn't the CEL light or is the bulb pulled?), & refuse to control the lockup, so you might just as well pull it, except if it controls fans & A/C then you might have to wire around that. Try to just unplug it and see what happens. There are different lockup kits available, & you could even make up one yourself relatively easy.
Old Mar 16, 2007 | 11:36 AM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
the ECM has nothing to do with the a/c
whole different circuit and harness, it is in the main car harness, the ECM harness is all by itself and the TCC lockup is in it though
good luck
Old Mar 16, 2007 | 08:38 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
i think you can buy the TCC lockup kit from Pro Built Trans.
http://www.700r4l60e.com/
Ions91Z28
Feb 14, 2002 01:50 PM
Roshambo
Pacific Northwest Region
Dec 11, 2001 03:30 PM
tacoboy
Oct 25, 2001 01:47 PM
dhirocz
Jun 18, 2001 02:10 AM
