I need the VATS programmed out...
Old Mar 20, 2007 | 11:17 PM
RAGEman's Avatar
Car: 87 Camaro Z28
I have a 94 LT1 in my Camaro, and I have used the Baker Electronice VATS bypass module to correct the VATS problem, and Im not positive that it is working. I don't know that it isnt, but the car starts and sputters and then dies, so I figured what the heck, I might as well program it out of the computer and see if that fixes my car problems. Who did you get to do yours? How much does this cost?
Old Mar 21, 2007 | 10:19 AM
Brads RS's Avatar
Re: I need the VATS programmed out...
Larrys electric 618-282-2852 can program it out along with any other changes you want except custom tuning. Its normally $100 dollars to reprogram the pcm. check out the web site. www.larryselectricsite.com
Old Mar 21, 2007 | 10:46 AM
bahsarie's Avatar
Car: 89 IROC-Z T-top C&C
there is a guy ebay that sells a box that gets rid of the vats by sending the signal that the vats box does to the ecm. ebay vats bypass. should be about 30 bucks total
RS Reaper
Oct 17, 2018 07:52 PM
FormulasOnly
Jul 23, 2018 08:47 AM
djmarch
May 8, 2016 11:32 AM
ULTM8Z
Oct 2, 2015 01:25 PM
AmorgetRS
Sep 28, 2015 09:33 PM
