engine wiring problem
i have a 1985 trans am with a 305 tpi engine and a 350 turbo transmission. i have 3 wires that come out of the main part of the wiring harness and at the left side of the engine come out of the plastic guard but are loose and aren't attached to anything. their colors are green, pink, and orange. i really have no idea where they should go and what to. please let me know if you know or know of a place that i could find out.
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: engine wiring problem
What kind of plugs are they? two-prong, three-prong, four-prong?
Car: 1985 & 1988 trans am
Engine: 350 tpi ; 355
Transmission: 700r4 auto; converting to 6 speed
Axle/Gears: 9 bolt 3:27 posi; 2.73 open
sounds like its from a relay of some type maybe fuel pump relay, a/c control fan relay, or secondary coolant fan relay
db057
Aug 11, 2015 10:11 PM
