My horn, electric door lock, and cd player aren't working???
Old Mar 28, 2007 | 07:29 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Title says it all. I got into my car and the CD player didn't come on. Later on I find out my electric door locks don't work. Soon after then, i find out my horn isn't working either. Any ideas?
Old Mar 28, 2007 | 07:39 PM
speedped79's Avatar
Car: 1982 z28
Re: My horn, electric door lock, and cd player aren't working???
im having the same issue except my windows sont work either
Old Mar 28, 2007 | 07:42 PM
83z28camaro's Avatar
Car: '01 GMC Sierra
Engine: 5.3L
Transmission: 4L60e
Axle/Gears: 3.73 eaton locker
blown acc fuse
Old Mar 28, 2007 | 10:55 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Yeah, It was the clear #25 fuse for me.
Old Mar 29, 2007 | 09:22 PM
cool84's Avatar
Car: 84 trans am
Transmission: built 700r4
it should say ctsy for that fuse, and it should be 25 amp
Old Mar 29, 2007 | 09:27 PM
speedped79's Avatar
Car: 1982 z28
mines still not fixed idk what it is
Old Mar 29, 2007 | 09:35 PM
cool84's Avatar
Car: 84 trans am
well if its not that fuse check further down. that draws its power from a wire connected to the positive terminal on the starter selinoid. there are like 3 wires that merge into that from the wireing harness, they have a fuse on the end of them its a thiner streatch of wire a few inches long that will burn up if it draws to much power. check those to see if they have power first
Old Apr 1, 2007 | 11:07 AM
Jaxom's Avatar
Car: '89 IROC-Z
Engine: StealthRam 355
Transmission: 6-speed
Axle/Gears: 3.70 9-bolt
If your accessory or courtesy fuse is blown you probably have a bad lighter socket. I see this problem a lot at work. Disconnect the lighter socket, replace the fuse, and see if that takes care of it.
Old Apr 2, 2007 | 12:43 PM
dv013003's Avatar
Car: Firebird Formula 350
Engine: 5.7
which wires?
hey cool84,
where are the three wires you're talking about located?
Old Apr 2, 2007 | 02:50 PM
1990camarogirl's Avatar
Car: 1990 Camaro RS/1992 Camaro RS
I have a similar problem only my CD player works but the horn, door locks, cig lighter, dome light and hatch release don't work. All the fuses are fine.
Old Oct 7, 2007 | 10:17 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Sorry about bringing this up from the dead, but The problem and grown worse. As soon as the fuse touches, it POPS. So when you say disconnect the Lighter socket, does that mean disconnect it all, or just the removable part? Because I dont have the lighter, just the socket. So Should I disconnect the socket and see if it still pops?
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
BlackTopKing
Aug 19, 2015 12:13 PM
