electronics help please
Old Mar 29, 2007 | 09:20 PM
92camaroz28ss's Avatar
Car: 92 z28
Engine: fast burn 385
Transmission: t56
first off let me start by saying i suck with electrical work.
now that thats out of the way, i have some switches in the car i am using to hook some things up. what i would like is to have power to them that will cut off with the key. what i have right now is a direct wire going to an empty circuit from the fuse box, however, it likes to blow the fuse for my gauges, causing them to not work at all. i was wondering if i could put a fuse back in for my fans and cut the wire going out of the fuse panel and take the power from there, i dont use my stock fan wiring as i put in an aftermarket controller for the fans.
i also want to know, that if the above is possible, that would give me one power wire going to these new switches. however, i have 4 or 5 switches, how can i split one wire to go to multiple switches? and just fyi i have circuit breakers on all switches to keep the electronics protected.
and lastly, if i can take the power from the fan circuit in the fuse box, how do i know what size fuse to put in there? or should i just get the power from the wire that goes into the fusebox not the one going out of the fuse box? meaning i would just take the power from the wire before the fusebox to eliminate the fuse at the fuse box.
i hope this is clear enough for understanding
and btw, thanks for any advice on this, i really am not good with electronics
Old Mar 29, 2007 | 09:29 PM
cool84's Avatar
Car: 84 trans am
Transmission: built 700r4
Re: electronics help please
wow i'm ok with electronics but that sounds way confuseing, i would say skip the stock fuse block and run a power wire from the battery to a relay and wire that into a hot key on wire, then run that relay's output to a small aftermarket fuseblock to work each of your switches. that way you can have each individual system protected by an appropriate fuse and will look a lot neater.
Old Mar 29, 2007 | 10:07 PM
Car: 92 z28
Transmission: t56
well the switches already have circuit breakers in them so i dont need fuses. i was basically just wanting to get the power from a wire thats already hot at the fuse box, hence taking it from the old fan fuse thats not in use any more. i dont want to have to add an aftermarket fuse box. i just want to have some hot leads going to a few switches that only come on with the key, is there any other way to do that?
Old Mar 30, 2007 | 10:35 AM
thedude's Avatar
Car: 85 Trans Am
Engine: LG4
Take a look at the fuse block. There will be empty terminals that have say IGN with arrows pointing to them. these supply power only when the ignition is turned on.
Old Mar 30, 2007 | 12:37 PM
Car: 92 z28
Transmission: t56
i did that to plug in my speedo converter box and thsta when it started blowing the gauge fuse. however, when i plugged it in before i didnt have a fuse on the power wire to the converter. this time i will have circuit breakers on every switch but am still worried about the gauge fuse blowing. will it make a difference this time now that i will have circuit breakers on the switches that will power the electronics?
InfernalVortex
Apr 20, 2021 11:31 AM
MrPackstin
Oct 25, 2017 08:09 PM
1992Z28!
Nov 19, 2015 07:33 AM
anesthes
Sep 30, 2015 07:48 AM
gta892000
Sep 16, 2015 12:37 AM
