Seat belt indicator lamp
Old Apr 4, 2007 | 03:38 PM
Guest
Guest
Posts: n/a
Hi,
I have a 1984 Trans Am.
There is a terminal behind the instrument cluster in one of the
connectors for the seat belt. (fasten belts)
How does it work? What is on that wire if the indicator is lighting
in the instrument cluster? GND or +12V?
Thank you,
Laszlo
Old Apr 4, 2007 | 04:52 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: Seat belt indicator lamp
If you go to our ATGO wiring diagram page, you will find a lots of diagrams there. Specifically, the "Fig16 1984 body wiring" diagram shows the "fasten belts" indicator. It is driven by the Audio Alarm Assembly in the Convenience Center that sends 12V to the bulb through a yellow wire. The seatbelt switch sends a grounding signal to the Audio Alarm Assembly through the black wire but I am not sure whether it's with the seat belt buckled or unbuckled, it doesn't show.
Hope this helps.
Lou
Old Apr 6, 2007 | 05:23 AM
Guest
Guest
Posts: n/a
Thank you for the info!
Laszlo
Old Apr 6, 2007 | 09:00 AM
BigBadLou's Avatar
Engine: TPI
No problem, that's what we're here for!
And many greets to Austria, the land next to the land where I was born.
Lou
Old Apr 6, 2007 | 11:41 AM
Guest
Guest
Posts: n/a
Where were you born?
Laszlo
Old Apr 7, 2007 | 11:33 AM
BigBadLou's Avatar
Engine: TPI
When I say Ostrava, that should ring a bell, eh?
Actually, right now, Texais COLDER than Central Europe. We have 5*C here at this moment (11:30am). Unbelievable. And the temperatures are supposed to "climb" up to 7*C. CCCCCCCOLD!!!! I want my 30*C back!!
Lou
ZMWojnar
Interior Parts Wanted
Sep 24, 2015 08:34 PM
scottmoyer
Sep 20, 2015 11:54 AM
MORREALE5
Sep 13, 2015 09:01 PM
iroczguy86
Sep 13, 2015 02:22 PM
MORREALE5
Sep 10, 2015 08:58 AM
