1990 IROC W/No Spark
Old Jun 26, 2005 | 10:43 PM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
My buddy just completed a motor rebuild and he can't get his 1990 IROC to fire. He checked the module and it's fine. The coil checks out as well. The thing ran good before the motor swap and we must have something miswired or ? It's a speed density motor. Any suggestions would be greatly appreciated. He has had the top end off this motor previously with no problems but he feels like it's something simple he's overlooking.
Old Apr 7, 2007 | 06:04 PM
cammed91's Avatar
Car: 1991 Pontiac Trans Am
Engine: 350 HSR, Cam, ignition, headers
Re: 1990 IROC W/No Spark
hey i know this is like 2 years old but do you happen to remember what was wrong with your engine? im having the same problem now. and i can't figure it out
Old Apr 7, 2007 | 06:14 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Well, first thing is to check the power supply (+12v) at the coil with the ignition on.
Next, try cranking without the EST connector disconnected.
Next...The ECM supplies the override pin (pin B on the module, look, it's labelled) with +5v when the engine is running. That is what tells the spark module to let the ECM control the timing. If that pin is getting +5v in crank, the car will not start correctly.
Frozer!!!
Jan 19, 2024 04:55 PM
Red iroc-z 305
Sep 30, 2015 05:22 PM
g.l.mos
Aug 22, 2015 12:02 AM
Dialed_In
Aug 20, 2015 01:45 PM
mustangman65_79
Aug 11, 2015 03:17 PM
