msd wiring problem
Old Apr 11, 2007 | 07:56 PM
blklblsk8r16's Avatar
msd wiring problem
when i bought my car it had an msd box bolted on but not wired to it. i know where the red and black wires go. but theres a green wire that i dont know where it goes then theres a single black wire with a plug on the end of it. then theres four wires (red black orange and white) this plug doesnt fit anywhere on my distributor. plz help thnx in advance.
Old Apr 11, 2007 | 08:00 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: msd wiring problem
What distributor are you using it with?
Old Apr 18, 2007 | 03:23 AM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
Do the black wire with a plug, and the green wires come out of the same hole in the case? on the left side of the box? Next to the tach output? Could the black wire be a dirty violet wire?
They would be for the magnetic trigger. The connector should have both wires in it.
The white wire would be for the elecric trigger, the red is ign. (heavy pink wire). The orange goes to the coil +,(B+) and the black goes to the coil -, (C -).
It would help to know the dist.
Check this out, it may help:
http://www.msdignition.com/pdf/6%20series/6series.pdf
Old Apr 23, 2007 | 08:32 PM
its the regular stock distributor. part number 1103679. ok i found out the black wire with the plug isnt a black wire its a green and violet wire covered in a black wire cover. on that same side of the box there is another green wire and then the other side has the connector. i dont know much about msd's or distributors so any info helps. thnx
Old Apr 23, 2007 | 08:45 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
See the link posted above.
Old Apr 24, 2007 | 08:11 PM
i tried but i dont have java so it wont let me view it. and i have dial up so downloading java will take almoost 8hrs
Old Apr 24, 2007 | 10:16 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Why do you need Java? It's just a PDF, you need Acrobat.
Old Apr 28, 2007 | 07:01 AM
i dont know but it just showed a bunch of symbols and letters.
BRoss99
Aug 10, 2025 05:08 PM
Infested
May 22, 2018 11:56 PM
toronto formula
Nov 10, 2015 06:17 AM
midias
Aug 15, 2015 05:07 PM
tartagliaz28
Aug 15, 2015 10:59 AM
