wiring my gauges
Old Apr 12, 2007 | 01:26 PM
83camaroking's Avatar
Car: 1983 Camaro Berlinetta 1989 RS
Engine: 355 sbc
Axle/Gears: posi 7.5 3.42
wiring my gauges
I got a set of sunpro gauges just the temp oil pressure and volt. I had no problem wiring the volt up but i wasnt sure where the oil pressure or the temp goes on the block. i know the temp hooks on the block somewhere i wasnt sure if it goes somewhat by the pcv valve or where. I have no clue where the oil pressure goes. Any suggestions welcome Thanks
Old Apr 12, 2007 | 01:53 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: wiring my gauges
Put the temperature sender into a port in either of the heads, or the intake manifold. The oil pressure sender can be put into the port at the back of the block near the distributor, or on the side of the block above the oil filter.
Ghettobird52
Jul 5, 2024 11:18 PM
Jeremys87
Jul 14, 2022 09:08 PM
rocn7roc
Sep 21, 2021 02:16 PM
355sbcTPI
Aug 19, 2015 04:38 PM
Jk_Under
Aug 17, 2015 03:08 PM
