hatch release harness 3 grounds or not?
Old Apr 21, 2007 | 11:01 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
i started hooking up hatch harness ,and i know 2 black ones with wire ends bolt in,but the one thats got me puzzled is a got another black one w/ a plug-end on it, know where it plugs in to?
Old Apr 21, 2007 | 11:27 AM
strokermotor91's Avatar
Car: 91 Camaro RS
Engine: Small Block
Transmission: TH350 w/ 3000 stall convertor
Axle/Gears: 3.73 w/ powertrax locker
Re: hatch release harness 3 grounds or not?
When i hooked mine up, one of the grounds go to the courtesy light in the hatch area. Try that out.
Old Apr 21, 2007 | 06:32 PM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
no ,that wasn't it .i got that all hooked up.puzzling
Old Apr 22, 2007 | 01:26 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Black wire with a black plug on the end? Sounds like the hatch solenoid power wire. Don't ask me why, but the wire powering the hatch release solenoid is BLACK. Oh, don't forget that you'll need to run a ground wire from the 10mm screw attaching the solenoid to the latch assy down to the ground location on the body below the pull-down assembly. The solenoid is electrically isolated from ground by the guides in the track, so that ground wire is required.
Lon
Hotrodboba400
Dec 10, 2019 07:07 PM
billybob6110
Sep 23, 2015 01:30 PM
2012sergen11
Interior Parts Wanted
Sep 7, 2015 11:37 AM
Jackrabbit501
Sep 2, 2015 09:14 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
