coil in cap to divorced coil
Old Apr 22, 2007 | 03:43 PM
Vash Vega's Avatar
Car: 1990 Iroc Z,2004 Z06 Corvette
Engine: 5.7 L98 tpi/LS6 346 ci
Transmission: 700r4/MN12
Axle/Gears: 10 bolt 3.23/DTE 3.42
what all do i have to do to swap to the smaller cap style
Old Apr 22, 2007 | 04:47 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Re: coil in cap to divorced coil
I did it, it's SO easy but you need all the parts.
You'll need:
The new distributor
coil/mounting bracket
the wiring pigtails: 1. 4 wire connector to distributor from harness, 2. distributor to coil, 3. 2 wire from coil to harness
And the main wire from coil to distributor.
The wiring was all the same color code on my car- very easy to swap. Just remember to check the firing order and timing afterwards.
MM2Robinson
Oct 1, 2017 09:16 AM
85 Jimmy
Sep 30, 2015 07:56 AM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
Jlanz55
Sep 9, 2015 09:09 AM
Jlanz55
Sep 6, 2015 03:05 PM
