new solenoid =dud?
Old Apr 22, 2007 | 11:38 PM
sinESter's Avatar
Car: 91 RS
Engine: 305 tbi
new solenoid =dud?
awhile back whenever i went to start my car i would turn it over and it would click. which meant my solenoid was bad, correct? well i replaced it and have been driving on it for a week in which it was great. then yesterday i went to start it and nothing happend when i turned the key over. i turn it over again and it starts right up. this morning i turn it over and get a click. turn it over and it starts right up. later in the day it takes like..5 times..Whats going on!?!?!?!
Old Apr 23, 2007 | 01:10 AM
speedracer0626's Avatar
Car: 89 Bird 93 Old Cutlass Ciera
Engine: 305/ 3.8 S.C.
Transmission: 700r4 and IDK
Axle/Gears: ????????
Re: new solenoid =dud?
I would say heat soak. Get some wrap or make a shield for it.
Old Apr 23, 2007 | 02:27 AM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
heat soak in the morning?? but a heat shield/wrap wouldnt hurt.. thing that comes to mind would be wiring.. ignition switch maybe? ground straps from battery??
Old Apr 23, 2007 | 05:27 AM
Corky's Avatar
Car: 88 Firebird - SOLD!
Engine: 2.8L
When you had the starter out did you check the Bendix drive, condition of teeth on drive gear and condition of armature bushings? You could have a problem with them as well. You could also have a problem with brushes worn. Solenoid could be working fine - If you hear the click, the drive gear could be pushed out to try & engage the flywheel, but if there is a problem with the starter motor, it won't turn over. You might need to pull the starter down & get inside.
Corky
Quzyle
Oct 15, 2015 03:35 PM
mcbitchman
Sep 30, 2015 01:00 PM
mcbitchman
Sep 29, 2015 12:32 AM
IROCZDAVE (88-L98)
Sep 22, 2015 02:22 PM
Racerx974
Sep 19, 2015 10:16 AM
