Speedometer Trouble
Old Apr 23, 2007 | 02:35 PM
Phoenix200's Avatar
Car: 1990 Camaro
Engine: 3.1
Speedometer Trouble
Hey everyone, I recently bought a 1990 V6 Camaro RS. The speedometer in the car doesn't seem to work right but all the other gauges do. It seems that the speedometer reads 0mph most of the time or jumps around but if I'm going up a hill or giving the car gas it will read correctly. I have already replaced the speed sensor with a new one but it didn't work at all so i put the original back in. I have also taken out the instrument panel to check for loose or dirty connections but we didn't see any. Does anyone have any suggestions? We're out of ideas, thanks for your help.
Old Apr 23, 2007 | 02:56 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Re: Speedometer Trouble
I've found with a sporadically working speedo that the wiring connections were the main source of problems. The connection at the back of the cluster and the connection at the vss. Vibration, bump in the road, cornering or change of angle causing the speedo to work, look for the circuit that goes open & complete.
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
mrbird
Oct 20, 2015 03:43 AM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
Bigold4x4
Sep 28, 2015 05:21 PM
