Push Button Start for 86 Z-28
Old Apr 23, 2007 | 04:20 PM
hendric5's Avatar
I've seen several posts for push button starters and remote starters, but none seemed to solve my problem. I've consulted my Haynes and Chilton and have been to countless websites for wiring diagrams. I am wanting to wire a mounted push-button start but still be able to use the key. I will still be using the key to activate the ACC tronics. Once I dropped the steering column and got a good look at the ignition switch, I was a bit confused. On the end closest to the steering wheel, there was a blue wiring harness with 2 red, 1 yellow, and 1 purple wire. Toward the firewall there was a black harness with many other different color wires. Could anyone tell me which are the two wires to connect the button to. My hunch was to connect the yellow and purple, but I can't find anything backing that up.
Old Apr 23, 2007 | 06:21 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Re: Push Button Start for 86 Z-28
The purple wire is the wire used to start the car. Provide power to that wire and then engine should turn over.
Old Apr 25, 2007 | 04:24 AM
hendric5's Avatar
I was able to get a little better access to the wiring harness today. Using a test light, the purple wire was the ACC hot wire and the yellow wire hot during crank. Using these wires, the push-button start was wired up without any problem and works fine.
Old Apr 25, 2007 | 06:19 PM
matt83z28's Avatar
Car: 83 z28
Engine: lu5
Transmission: 700r4 that works good.
Axle/Gears: G92 3.23
sounds pretty nice... where did you mount the push button?
Old Apr 25, 2007 | 06:33 PM
85_ZED28's Avatar
Car: '85 Z28
how did you end up wiring it?
Old Apr 26, 2007 | 05:46 PM
Toehead's Avatar
i know for a fact my car is purple wire hot to solenoid to crank. I just finished doing a motor swap ! lol
Maybe yours is different, idk.
Old Apr 26, 2007 | 09:16 PM
VenomX-87's Avatar
Car: 1984 Trans-Am WS6
Engine: WAS: 5.0HO, SOON: ZZ383-425HP.
Transmission: 700R4 with shift kit
Here is my setup and location, Hope it helps someone out.
UPDATED PICTURE:
Attached Thumbnails Push Button Start for 86 Z-28-image000-2.jpg   Push Button Start for 86 Z-28-starter.jpg
Orr89RocZ
Apr 25, 2016 08:28 AM
The_Phoenix
Feb 4, 2016 07:10 AM
smooth
Aug 18, 2015 06:34 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Tony Ferrarri
Aug 11, 2015 07:59 PM
