will bad pump shut off injectors?
Old May 1, 2007 | 08:04 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
a (friend )said if the pump goes bad the power to the injectors is shut down.is that true?
Old May 1, 2007 | 09:57 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: will bad pump shut off injectors?
Nope.
There is no feedback between the pump and the injectors. The injectors will try to open even if there is zero fuel pressure. There is no fuel pressure sender on our cars to tell the ECM.
Lou
Old May 1, 2007 | 12:33 PM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
well lou i don't know whats up with this car then ,the fuses are good,i put a new f/p relay on it ,and still no power to the injectors.everything works on this car ,but the injectors.and its firing real well.
Old May 1, 2007 | 03:51 PM
BigBadLou's Avatar
Engine: TPI
Do the pink/black and pink wires on the injectors have 12V?
If not, it's a power problem (fuse, wiring).
Do you see no ground pulses on the blue and green wires on the injectors?
If not, it's an ECM or VATS problem (or wiring again).
Lou
P.S.: Please put TBI in your profile. That way, we won't have to search through your other posts every time we reply.
Old May 1, 2007 | 05:14 PM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
ok, i edited my profile thanks bringing it to my attn. it's probably the vats. it's just hard to believe that 2 different vats systems could be bad,2 different ecm.i traced wires,none broke or anything it must be the vats decoder ,cuz,the key measures out with the wires i even did the resistor deal and still no injectors.
Old May 1, 2007 | 05:20 PM
BigBadLou's Avatar
Engine: TPI
I'm still not sure what exactly is the problem. Are you missing 12V on the injectors or the grounding pulses from the ECM?
If I can assume it's the grounding of the injectors , you can try grounding pins D14 and D15 on the ECM (with key ON) and checking if that squirts fuel into the intake. If not, it would point to a wiring issue between ECM and injectors.
Lou
Old May 1, 2007 | 06:43 PM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
ok, i will try it in the morning.and post outcome.
Old May 1, 2007 | 07:33 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
Nevermind....
Old May 2, 2007 | 04:34 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
my injector wires are reb,blue on one side, and green ,white on the other.
Old May 2, 2007 | 06:15 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
grouding the pins had no effect.however when i traced my injector wires down the red and white ended up going to a clear looking connector that plugs into nothing.the clear connector ran down by the ecm ,but branched off.i dont ever remember it being plugged into anything.
Old May 2, 2007 | 07:26 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
bite my tongue ,the clear ones did connect.now i have power to injectors ,but stiil no fuel.i can hear the pump kick on and everything.i still get no pulse at those other wires ,but when i ground them now i can hear a clicking
Old May 2, 2007 | 09:27 AM
BigBadLou's Avatar
Engine: TPI
Alright, progress.
First of all, these wire colors definitely don't correspond to GM wiring diagrams. Not sure what that's all about. Engine swap maybe?
As for the injector grounding. If you have 12V to the injectors (verify with a voltmeter) with the key ON and you ground the OTHER wire on the injectors, does the clicking come from the injector itself? If so, that would mean that they MOST likely work.
Now why aren't they spraying fuel? Did you check fuel pressure at the throttle body?
Lou
Old May 2, 2007 | 02:44 PM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
i order a vats bypass from bakers electronics thats supposed to run the ejectors only,do youi know how these hook up?
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
Bryan F
Aug 18, 2015 02:28 PM
djmarch
Aug 9, 2015 05:27 PM
