quick distributor wiring question
Old May 3, 2007 | 10:31 AM
voodoo427's Avatar
Transmission: th350
a buddy of mine is swapping from his tpi setup to carb. and is wanting to know if the grey connector with the two wires are the wires he needs to hookup for his new hei power and tach feeds.i believe his is a 87
Old May 3, 2007 | 12:45 PM
DillonRager's Avatar
Re: quick distributor wiring question
if the connector has red and yellow wires going to it then the red is power i just did mine but i dont have a tach so i dont know if the yellow one is tach but i assume it is. check to make sure that the red wire only has power when the key is on before you do it .
Caspar
Jun 19, 2016 11:19 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
stalkier
Aug 7, 2015 04:49 AM
L98GTA87
Aug 5, 2015 11:02 PM
