I Cant Read Wiring Diagrams!! 1985 tpi help!
Old May 7, 2007 | 08:50 PM
quintdavison's Avatar
hi, i am trying to wire up a engine and drivetrain from a 85 camaro into a rx7.. i was thinking of upgrading to newer electronics but i heard this was the most standalone system.. any comments on that? ok now the question.. where the harness goes to the ecm.. there are 4 plugs, 2 to the ecm, 1 to the maf burnoff module.. and then the last one.. which i think goes to the dash harness.. i need a diagrams or color coded thing that says what all those wires are.. can someone point me in the right direction.. i looked but only come up with the 2 ecm plug diagrams. thanks
Old May 8, 2007 | 11:08 PM
Re: I Cant Read Wiring Diagrams!! 1985 tpi help!
so nobody knows... hmm
Old May 9, 2007 | 09:10 AM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
I am not sure.
I am sure that somebody knows.
Old May 9, 2007 | 12:09 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
That 4th connector you're asking about is called C207. Do a search here and find the one for your year. I'm sure it's been posted here before.
Hope this helps.
Lou
Old May 9, 2007 | 05:15 PM
BigBadLou's Avatar
Engine: TPI
Here, found this for you: https://www.thirdgen.org/forums/elec...ctor-c207.html
Hope this helps.
Lou
Old May 9, 2007 | 08:35 PM
thanks so much! thats exactly what i needed! now i just need the other side of the plug with about 6" of wires to go into my car... and the ALDL plug with the same... hmmm
Old May 10, 2007 | 08:39 AM
BigBadLou's Avatar
Engine: TPI
You're welcome. That's what we're here for.
You can post in the classifieds section about the C207. Many folks here part out cars, I'm sure somebody has that piece of harness.
Lou
eightsixseven
Dec 16, 2024 01:50 PM
Caspar
Jun 19, 2016 11:19 PM
Reddeath210
Oct 6, 2015 08:20 AM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
