lookin to get rid of the points dis setup and goin electronic! help
Old May 11, 2007 | 03:36 PM
355tpipickup's Avatar
Car: 92 1500p\u 2wd
Engine: 91 z28 tpi 355
Transmission: 91 700r4
im lookin for help on what i need to for a built 327 motor from a 64 ss impalla thats in a 74 camaro. it has the older points dis setup now and we want to do a electronic setup.....what parts are needed to do this swap?
Old May 11, 2007 | 04:03 PM
Rayvan's Avatar
Car: '89 Formula WS6 N10 No T-Tops
Engine: LB9 225HP
Axle/Gears: 3:45BW
Re: lookin to get rid of the points dis setup and goin electronic! help
This is off topic and may be closed at any time...
Just get an HEI distributor *with vacuum advance* from a 1976 Small-Block Chevy powered vehicle. It needs a full 12Volts so you'll need to get rid of the ballast resistor that powers your current distributor. You won't need the wire that comes from the starter solenoid.
That is all!
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
86CamaroDan
Sep 29, 2015 10:08 PM
TheExaminer
Sep 6, 2015 11:40 PM
SG91camaro
Sep 5, 2015 10:27 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
