heat/air fan short...
Old May 15, 2007 | 01:33 PM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
Is there a ground wire connected to the heater fan. As of two days ago everytime I hit a bump the fan cuts off or on. It must be a ground somewhere.
Old May 15, 2007 | 03:54 PM
rhomanski's Avatar
Car: 86 firebird v6,86 corvette,88 GTA
Engine: 350 C.I.,2.8l.
Transmission: th700r4
Axle/Gears: 3:08,3:27
Re: heat/air fan short...
There's a ground lug under one of the bolts that hold the fan on the heater box,but i would suspect you need a new fan.You can get one at a parts store but it may be better to get one used or from the dealer because of fitment issues with an aftermarket.You have to swap the cage over and the shaft hole may be different.
Old May 15, 2007 | 06:10 PM
IROC 86's Avatar
sounds like to be you better look for a loose wire. if the fan turns on then it is most likely not the issue. clean your ground wires and look for wires with broken shielding on the that could be shorting out your fan as well.
Old May 15, 2007 | 07:11 PM
Corky's Avatar
Car: 88 Firebird - SOLD!
Engine: 2.8L
Run a temporary ground wire and drive around. If fan stays running you found your problem. If it doesn't, check your positive wiring for a loose connection. If neither one works, you probably need a new fan motor - Afterall it's over 20yrs old.
Corky
Old May 16, 2007 | 12:02 AM
Axle/Gears: Posi
Where is the fan located? And where is the ground located? thanks
Old May 16, 2007 | 05:42 PM
rhomanski's Avatar
The fan is under the hood on the passenger side on the firewall.It's mounted on the heater box.A big plastic box on the firewall.The fan is a shiny black round thing held in by about seven bolts.It has a hot wire a ground and a rubber cooling tube.You'll need to disconnect it,take the bolts out,and pry it off the heater box.Then you'll need to transfer the cage over to the new motor.Then reinstall the assembly,I use a little rtv on the flange to seal the fan to the box.
Old May 18, 2007 | 03:34 AM
Axle/Gears: Posi
Old May 18, 2007 | 05:30 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
https://www.thirdgen.org/forums/elec...C+switch+brown
JamesC
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
BrianI
Oct 3, 2015 12:57 PM
Fanatic1074
Oct 2, 2015 03:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
