wire up fuel pump
Old May 19, 2007 | 08:23 PM
89irocTPI's Avatar
wire up fuel pump
how can i wire up a toggle switch so i can manualy turn on and off the factory intake fuel pump
Old May 21, 2007 | 03:39 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: wire up fuel pump
I assume you need this for a 1989 Iroc with a TPI engine.
You would need to find the fuel pump relay first. It has 5 wires: black/white, green/white, tan/white, orange, red. You can run a switched fused +12V to the green/white wire.
However, this is just a nasty hack. If you have a problem with the fuel pump circuit, I would recommend fixing it. It would be a hazard to have a switch that overrides the stock system.
Lou
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
Infested
May 22, 2018 11:56 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
