no power to accessories!
Old May 20, 2007 | 07:43 PM
Dirtbik3r's Avatar
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
What doesn't work?
cigar lighter
dome light
instrument cluster lights
headlight switch
power hatch release
I understand all these are wired through the acc fuse. Which I just checked and has 12v. I then went to power for the cigar lighter and that has no juice. What could be causing this to happen out of nowhere?
Old May 20, 2007 | 07:49 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: no power to accessories!
Are those the only things that lost power? I would double check all the fuses. I had the same thing happen and it was a fuse.
Old May 20, 2007 | 07:54 PM
Corky's Avatar
Car: 88 Firebird - SOLD!
Engine: 2.8L
Remember, you can have 12v at the fuse, but you have to check both sides of the fuse. Must have power in & out of the fuse. This sounds like classic acc fuse blown.
Corky
Old May 20, 2007 | 08:02 PM
Dirtbik3r's Avatar
With the fuse out, only one pin of the fuse holder should have power...(open circuit voltage) I even tried putting in a different fuse and it didn't work. And they arn't blowing which means most likely, there is not a short of some sort. A wiring diagram would probably solve my problem. I'm doing this blind right now without one.
Old May 20, 2007 | 09:16 PM
Dirtbik3r's Avatar
alright, found it. It was the fuse on the neer pass side fender. It had corrosion on it.
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
