manualy wire fuel pump
Old May 21, 2007 | 06:52 AM
89irocTPI's Avatar
I bought a rocker switch to wire up my fuel pump the switch says power, load, ground. So i figure ground the ground terminal get power from the fuse box to the power side and the load side should be hooked up to the power wire to the fuel pump correct? I plan to get the power wire from the fuel pump relay the tan/white wire is this going to work?
Old May 21, 2007 | 09:11 AM
92droptopws6's Avatar
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
Re: manualy wire fuel pump
bypass the factory power lead all together,run a 12guage lead from the acc lead at fuse panel run to the fuel pump,cut the factory power wire and splice HOT lead to pump harness
look here www.racetronix.com and look at the HOT wire,wire harness
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
Infested
May 22, 2018 11:56 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
