Erratic headlight motors
Old May 24, 2007 | 10:52 AM
Freakazooid52's Avatar
Car: 1986 firebird
Transmission: THM350
Its on my 1986 firebird, One headlight would come up and not go down and the other would do nothing. I took both motors apart seeing if they needed the nylon gear replaced, they dont. both of them spin when giving volts.
Where in the electircal for these motors could my problem be? headlight switch?
Old May 27, 2007 | 03:43 PM
gtatech's Avatar
Re: Erratic headlight motors
look at the headlight motor controller on the firewall next to the brake booster,take the connectors and tighten the connector pins.the way to check it is to have an assistant operate the headlights and wiggle the connector and you will see the motors will work.
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
GTAman
Mar 15, 2019 11:40 AM
LittleFranks
Sep 17, 2015 12:22 PM
stalkier
Aug 13, 2015 12:59 PM
