Temp Gauge/Melted Wire
Old Jun 2, 2007 | 10:01 PM
DamienZ's Avatar
Hello everyone, i just purchased a 85Z 305 TBI this week. Im having problems diagnosing my temp gauge. Right now, the gauge stays pegged at all times. Even when the car isnt started. I have read through the forums and decided the disconnect/ground procedure, to check the gauge, and it didnt change at all, either way. . I did notice that the connector that clips on the sending unit is a little melted by the metal "clip" area. I just really need some advice on what to try to tackle first. Is it more than likely the sending unit, wire, or the actual guage. I appreciate any feedback, and if i need to replace the wire, where/how is the best way to do it, Thanks in advance for any help .
Damien
Old Jun 2, 2007 | 10:16 PM
82CAMAROBBC's Avatar
Car: 1982 Camaro
Engine: 454
Transmission: TH350
Axle/Gears: 410
Re: Temp Gauge/Melted Wire
If you disconnected for the sending unit and no change..its not the sending unit. what it sounds like is the wire is pinched and shorted to ground. Trace the wire back the the firewall. It enters through the firewall by the Brake booster. If you dont find any problems with the wire the guage may be bad..
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
bamaboy0323
Aug 15, 2015 07:20 AM
