2 Step and Line Loc
Old Jun 3, 2007 | 04:51 AM
JesasaurusRex's Avatar
2 Step and Line Loc
Ok so i'm pretty sure i figured out how to wire my 2 step and line correctly but i'm trying to figure out how to wire in my neutral safety switch. The way i have it drawn out the push button should active the line lock at any given time and the 2 step when the clutch is pushed in (5 speed car). Bleach box -> hold clutch in plus momentary button (line loc and 2 step on) - > dump clutch with finger still on button (line loc still on 2 step off) and do the burn out - > stage, clutch in, finger on button, while still in gear hold it WOT (line loc on, boucning off the 2 step), Dump clutch and finger off the button and away we go.
So my initial question is, by the "drawing" (im no artist ) have i wired it correctly? If not where did I go wrong, and if I did wire it right but you know of a better more efficient way to do it please tell me that as well, i'm open to new ideas.
Now my second question is this, i have never really used a neutral safety switch in this car to prevent the starter from engaging. However now i'm like hell why not, im playing around with it anyways might as well do it as a bonus. So how can I tie the starter into the neutral safety switch and get the starter to work with OUT having to push the momentary push button as well. I just can't figure it out so i need help, if i'm sh*t out of luck screw it, ill just not use it since that's nothing new . Thanks in advance
-Rex
Old Jun 3, 2007 | 10:36 PM
Re: 2 Step and Line Loc
bumpity bump
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
Chad Speier
Sep 24, 2015 12:32 PM
e3pres
Sep 9, 2015 01:51 PM
