No Juice
Old Jun 3, 2007 | 02:56 PM
cooter26's Avatar
Car: 83 Camaro
Engine: 383
Axle/Gears: 4th gen 10 bolt 3:42 POSI
No Juice
I have no power to winshield wipers, blower motor, and windows. I have power everywhere else, power door locks, ignition, dome light. I am also having trouble with my temp sensor gauge and tac. I have checked all fuses. Any ideas?
Old Jun 4, 2007 | 12:29 AM
82CrossFire Z28's Avatar
Car: 82 Camaro Z28, 88 IROC-Z
Engine: 5.0L TBI., 5.7TPI
Transmission: Auto TH200C, 700R4
Axle/Gears: 3.23 posi, ones that rotate!
Re: No Juice
Typically the fuses for the Wipers, AC/Heater and Power Windows are only HOT in RUN. So the ignition key must be in the run position to connect these circuits to the battery/generator. There may be a fuseable link in the wire from the battery to the ignition switch contact that powers these fuses. You will need to confirm if you have a fusible link, and it it has melted or not. A fusible link works like a fuse, too much current through it and it melts.
Old Jun 4, 2007 | 11:22 AM
cooter26's Avatar
Car: 83 Camaro
Engine: 383
Re: No Juice
Thanks, I will search for that tonight.
Old Jun 4, 2007 | 08:32 PM
cooter26's Avatar
Car: 83 Camaro
Engine: 383
Re: No Juice
Well i havent figured it out yet, but i found a realy great diagram with all the wires and locations. Thanks for the help
JSDaddy189
Sep 26, 2015 03:50 PM
GofasterFirebird
Mar 16, 2002 09:32 AM
IROC-KET
Nov 27, 2001 04:31 PM
chevyboy07 91
Apr 2, 2001 04:46 PM
trevor92rs
Feb 10, 2001 09:23 PM
