Fuse Panel Contents
Old Jun 13, 2007 | 11:17 AM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Fuse Panel Contents
Anyone have a list of the fuses needed and what sizes for an 89 LO3 Camaro?
When I bought the car it was missing 3 fuses and some were blown so I decided to replace them all. Now I just need to know the 3 that didnt have anything in them. I know for sure two are F/P INJ2 and ACC.
I read in another thread on here that F/P INJ2 was injector number 2?
I was told ACC was ACCESSORIES but all of mine worked?
P.S. A List would work wonders and NO I DO NOT have a fuse panel cover.
-H8 To Be Pulled, But Love To Be Pushed!
Old Jun 13, 2007 | 11:46 AM
ChillPhatCat's Avatar
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
Re: Fuse Panel Contents
Is there anything that doesn't work? I wouldn't just start putting fuses in the empty slots unless you have reason to believe that they actually were there in the first place. All the fuse panels were the same and some of the fuse slots will not have anything in them because those items weren't equipped. The ACC location should have a fuse there... it's one of the two large 35A fuses. I think INJ2 is only for TPI cars.
Old Jun 13, 2007 | 11:54 AM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Everything workes fine. The ACC DOES NOT have a 35A fuse. I know that for sure because the only 2 that do were already in the car so I didnt touch those yet as I dont have those fuses to replace it yet. Do you have your fuse panel handy? Thanks.
P.S. I heard a guy talking about taking out his INJ2 fuse when he was replacing his injector o-rings on his LO3.
Old Jun 13, 2007 | 06:30 PM
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
I too don't have a fuse panel like yourself, but I've got this diagram which is accurate.
Old Jun 13, 2007 | 09:21 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Still mine is different. Where it says CTSY mine says ACC, but the rest thanks.
Now which ones must have fuses as like I said I found 3 without any fuses and I dont remember which ones except two ACC, and F/P INJ2
thunder57
Nov 7, 2015 02:28 PM
meeklay812
Oct 1, 2015 03:46 PM
formula00ra
Interior Parts Wanted
Sep 28, 2015 11:50 AM
lanceflame44
Sep 25, 2015 12:28 PM
