My plan for wiring in LC1 wideband
Old Jun 14, 2007 | 07:08 PM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
I bought a LC-1 wideband the other day and I was trying to come up with a good wiring harness for it.
I have heard a lot of comments about defective controllers, mostly assumed to be caused by voltage irregularities during cranking. So I have thought about how to avoid this problem.
I was thinking of adding an extra hidden switch into the cabin for switching 12v to the sensor. I was also thinking of splicing into the ignition 12v source that used to run to the AIR diverter valve, (which through reading wiring diagrams would be on the gauges fuse).
So I'd have the power from the ignition wire going to a switch, and then into the lc-1.
Would that be too much load on the gauges circuit?
What gauge wire should I run from the ignition wire source to the switch inside the car and then back out into the engine bay to the controller?
Should I add an addition inline fuse before the switch?
Old Jun 16, 2007 | 04:19 PM
Car: 91 Camaro RS
Re: My plan for wiring in LC1 wideband
I planned on using an extra inline 5 amp fuse just for protection on the rest of the circuit. The switch I selected is a very basic toggle that is only rated at 6 amps as well. I plan on using 14 guage wire for all of the power supply and joint grounds.
I thought finding a place to put the o2 in the exhaust would be the easy part, but I am still undecided on that.
Old Sep 7, 2007 | 11:41 AM
gapimpin's Avatar
Car: 1991 Pontiac Firebird
Engine: 383 LT1
Transmission: built 700r4 and fuddle 3500stall
Axle/Gears: 4th gen 3.42 auburn
so how did this work out for you guys?
i just ordered my lc-1 and am gonna try to wire it up this weekend
Jorlain
Aug 24, 2022 05:11 PM
Jeremys87
Jul 14, 2022 09:08 PM
Caspar
Jun 19, 2016 11:19 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
L98GTA87
Aug 5, 2015 11:02 PM
