Starter problem
Old Jun 17, 2007 | 10:21 PM
408Firebird's Avatar
Car: 1991 Firebird
Engine: 408 sbc
Transmission: Th-350
Axle/Gears: 10 Bolt / 3.73
Starter problem
So my starter died in my 400 sb and I bought the same starter as I had before which was a high torque mini starter part # 170-100SBP. With my old starter it would grind every once in a while but start up for the most part every single time. When I got the new starter I made sure that everything was the same I even used the same shims I had before. It started up fine on the first start up but then the starter started to become loose so I tighted it as much as I could. Now when i go to start it it grinds very bad. What should I do?
Spyder_TheGamer
Dec 25, 2015 05:07 PM
5spdcamaro
Aug 28, 2015 02:12 AM
92camaroJoe
Aug 13, 2015 06:07 AM
milk
Aug 10, 2015 06:26 PM
