Could someone check the voltage of thier alternator for me?
Old Jun 19, 2007 | 02:41 PM
88TransAmFreak's Avatar
Car: 1971 Camaro
Could someone measure thier alternator and tell me what it's putting out @ idle voltage wise? Thanks!
My car's a 1990 TPI set-up and it's only putting out around 11.99 - 12.00 volts @ idle......two different parts stores says my alternator is fine...it's brand new and the battery is new.
Old Jun 19, 2007 | 04:20 PM
bilms01's Avatar
Car: 89 Firebird
Engine: 350 Ramjet
Axle/Gears: GM 9 bolt 3:27
Re: Could someone check the voltage of thier alternator for me?
A fully charged battery should read 12.6V and a good alternator should have a 13-14 Volt output. If the alternator tests good at two different places you might have a wiring issue with the wires that plug into the regulator.
Old Jun 20, 2007 | 07:04 PM
Car: 1971 Camaro
Hey thanks for the reply,
I figured it out, one of the wires on the plug that went to the bulb in the dash was acting up. The bulb was blown...fixed that and started getting 14.5 volts again.
Old Jun 20, 2007 | 09:03 PM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
13.2-14.8 Volts is good, anything lower, or above, is bad.
eightsixseven
Dec 16, 2024 01:50 PM
GTAman
Mar 15, 2019 11:40 AM
Cornholio7979
Sep 20, 2018 02:31 AM
GTAman
Sep 21, 2015 09:57 AM
